| Continuity check of coil https://slantsix.org/forum/viewtopic.php?t=4103 |
| Author: | Tom Glander [ Sat Aug 31, 2002 5:21 pm ] |
| Post subject: | Continuity check of coil |
If I set my voltmeter to the continuity test setting, then check across the "+" and "-" posts on the coil, I get a tone. Should this be so? I would think that there should be no continuity between + and - on the coil. Am I right or wrong? Still trying to suss out the reason for the goofy electrical "issues" with the 225 /6 on the '66 Valiant. Thanks ye gurus. tomglander@netzero.net |
| Author: | GaryS [ Sat Aug 31, 2002 7:12 pm ] |
| Post subject: | Re: Continuity check of coil |
You will have continuity between the + and - terminals. They are the two ends of the same wire. You should have a high resistance between the + and - terminals and the center terminal. If not, it's shorted inside. Different coils will give different readings. Check the coil for bulges or leaking. That's a fairly common sign when they go bad, but they can look perfect and still fail. Quote:
: : If I set my voltmeter to the continuity test : setting, then check across the "+" : and "-" posts on the coil, I get a : tone. Should this be so? I would think that : there should be no continuity between + and : - on the coil. Am I right or wrong? : : Still trying to suss out the reason for the : goofy : electrical "issues" with the 225 /6 : on the '66 Valiant. : : Thanks ye gurus. lancer_41@excite.com |
