| EGR vacuum hose routing for 78 Slant 6 w BBD carb https://slantsix.org/forum/viewtopic.php?t=41043 |
| Author: | itlldo1 [ Wed Jul 14, 2010 1:47 pm ] |
| Post subject: | EGR vacuum hose routing for 78 Slant 6 w BBD carb |
I've searched through numerous threads, but can't find what I'm looking for. I'm trying to hook up my EGR system on my 78 D100 with a BBD. Can I do this quick and dirty w/o using the vacuum amplifier-just a vac source from the carb through the temperature sensor in the radiator? If not, while I'm waiting for my factory service manual to arrive, does anyone have a map of the vac hose hookup through the amplifier? I don't have the 4 hose harness with the color coded markings. I'm doing this to hopefully eliminate a pinging problem after numerous carb adjustments w modified settings, checking for vac leaks, spring replacement and, different pot adjustment in the distributor. I'm currently running 10 degree base timing with a total of an additional 27 combined vac/mechanical advance. Get a heavy pinging when hot on a pull, or accellerating. Running a 180 stat, with a cold air kit to the carb. Thanks- Mike |
| Author: | Aggressive Ted [ Wed Jul 14, 2010 2:23 pm ] |
Several times they have been posted here and were pdf pages from the FSM. Here is a good link with a nice pdf diagram http://www.slantsix.org/forum/viewtopic ... ram#141151 By chance, did you look at all of Dan's carb links? You also can get them from doing a Google search.... |
