It is currently Fri Jun 12, 2026 11:33 am
 Post subject: newer head
PostPosted: Fri Jul 16, 2010 5:34 pm
well, i've got the block at the machine shop for the rebuild, but now want to consider heads. i would like to get away from the leaky spark plug tubes and go with a later head. would the 75-80 heads work alright on my 72 block and what casting # should i look out for? mine has no smog pump or egr. oh ya, does all heads oil the same way ? thanks, dave.
PostPosted: Fri Jul 16, 2010 6:13 pm
You can use any of the later heads all the way up to the end. The '81-'87 hydraulic head will accept the mechanical rockers also. Only major differences will be the '81 and up take the late style valve cover, and '75 or so on up will have a different 'step' style bolt in the rear rocker stand instead of a 3/8".
The '75-'80 heads have small holes for the pushrods that you would not be able to fish lifters out through, if that is a worry.
PostPosted: Fri Jul 16, 2010 6:52 pm
thanx for the reply. there's nothing wrong with mine, if i knew i could put it on without it leaking i would just use the original one. can u get new seals for the tubes? dave.
PostPosted: Fri Jul 16, 2010 7:10 pm
Yep. Fel-Pro #ES 12794 is a box of 6 gaskets for the spark plug tubes. I think I paid $4 for the whole set.
PostPosted: Sat Jul 17, 2010 11:51 am
Yes, RockAuto has them for $3.42
