Sway bar on a '63
https://slantsix.org/forum/viewtopic.php?t=41118
Author:  hellion_locdogg [ Tue Jul 20, 2010 8:17 pm ]
Post subject:  Sway bar on a '63
Are there any special brackets or mounts that I will need to look for?
I am making and welding my own LCA mounts and buying the hoop mounts. Am I missing anything special?
,Cliff
Author:  Mister Twister [ Wed Jul 21, 2010 3:26 am ]
You have the parts lits right. :) If you have the bar correct, when mounted to the lower control arms. I found that 1" of tension pushing the bar where straps can then bolt on, is just fine. More than that if your cornering hard. :shock:
Author:  Dart270 [ Wed Jul 21, 2010 6:31 am ]
Stock 62-66 sway bar?? Addco?
