It is currently Thu Oct 22, 2026 7:36 am
PostPosted: Mon Sep 02, 2002 5:39 pm
I am going to turbo my Duster with a 225/4-spd-OD.
So im still not sure in a few areas.
-I remember hearing that a BB Mopar fuel pump will fit the slant if i swap the slant arm into the the BB pump, is this true? I think i would feel better having a boost refrenced BB pump, this way i could have 3/8 line the whole way.
-Is the MSD BTM absolutely necessary? If i retard the timing 5-7 degrees will i be ok?
-Should i keep my dual 2" Flowmater exhaust, and run a y-pipe into the turbo, or sell it and run a single 3" into a Magnaflow muffler, with dual 2.5" outlets? The flowmasters are a little too loud actually, i dont want to get negative attention from the law enforcement:)
Thanks, Tom B
tommyb1515@aol.com
PostPosted: Mon Sep 02, 2002 7:13 pm
: I am going to turbo my Duster with a
: 225/4-spd-OD.
: So im still not sure in a few areas.
: -I remember hearing that a BB Mopar fuel pump
: will fit the slant if i swap the slant arm
: into the the BB pump, is this true? I think
: i would feel better having a boost refrenced
: BB pump, this way i could have 3/8 line the
: whole way.
I tried this, but after getting the fuel pump off and taking a look at them it looked like a bit more work than I wanted. So I just put an electric pump with a boost referenced pressure regulator on there instead. It certainly appears possible, but I wasn't sure how to remove the pin that was holding the arm in place easily; the only thing I could think of was drilling it out. If you want the BB fuel pump, I could sell you the brand new one I bought for the conversion.
: -Is the MSD BTM absolutely necessary? If i
: retard the timing 5-7 degrees will i be ok?
I've heard of turbo setups being done without a pressure retard, but the BTM will be helpful in making more power than with no system to retard timing under boost.
: -Should i keep my dual 2" Flowmater
: exhaust, and run a y-pipe into the turbo, or
: sell it and run a single 3" into a
: Magnaflow muffler, with dual 2.5"
: outlets? The flowmasters are a little too
: loud actually, i dont want to get negative
: attention from the law enforcement:)
: Thanks, Tom B
I don't have flowbench data for the Flowmasters or Magnaflow, but I'm guessing two mufflers will be better than one, and the Flowmasters should certainly work. If the Magnaflow is a good straight through design, chances are neither muffler setup will offer a performance gain.
Matt
PostPosted: Tue Sep 03, 2002 6:27 am
: whole way.
I went this route myself, but I'm a little disapointed with the results. Next week I'm installing a Carter electric pump with a NOS vacume/boost refrenced regulator. My fuel pressure is a little weak at idle when I first start the car, takes about half a minute to come up, and I seem to run out of pressure at about 80 mph if I jump on it.
I did the turbo first without the MSD BTM. About a month later I added it. Huge differance all the way around! (especially at low rpm)
A turbo has a good deal of muffler efect on the exhaust. I ended up just doing 2 1/2" single pipe with a large stainless steel resonator off of a Mitabitchy. You'll probably be OK with the Flomasters.
Dan M.
slantedsix225@aol.com
PostPosted: Tue Sep 03, 2002 7:03 pm
I ran a flowmaster on mine for a while. It works fine and I really liked the sound, but a straight thru muffler is the way to go with a turbo car. I also have the msd btm and I would not be with out one!
andrew wagner
: I tried this, but after getting the fuel pump
: off and taking a look at them it looked like
: a bit more work than I wanted. So I just put
: an electric pump with a boost referenced
: pressure regulator on there instead. It
: certainly appears possible, but I wasn't
: sure how to remove the pin that was holding
: the arm in place easily; the only thing I
: could think of was drilling it out. If you
: want the BB fuel pump, I could sell you the
: brand new one I bought for the conversion.
: I've heard of turbo setups being done without a
: pressure retard, but the BTM will be helpful
: in making more power than with no system to
: retard timing under boost.
: I don't have flowbench data for the Flowmasters
: or Magnaflow, but I'm guessing two mufflers
: will be better than one, and the Flowmasters
: should certainly work. If the Magnaflow is a
: good straight through design, chances are
: neither muffler setup will offer a
: performance gain.
: Matt
Users browsing this forum: Amazon [Bot] and 21 guests
