| getting old gaskets off? https://slantsix.org/forum/viewtopic.php?t=41192 |
| Author: | Rust collector [ Mon Jul 26, 2010 5:06 am ] |
| Post subject: | getting old gaskets off? |
What should I use to get old nasty gaskets off? I am working on my cherokee oilpan gasket, and there is a lot of stuff in the way, and the gasket is pretty tough to get off. Can I use acetone to soften the gasket a bit? Paint stripper? Torch? I just don't want to WALK 2 hours to town to get gasket remover spray, if I can use something around the house... |
| Author: | oldblue [ Mon Jul 26, 2010 8:33 am ] |
Goof off or lacquer thinner.Very flammable so be careful. |
| Author: | ESP47 [ Mon Jul 26, 2010 8:45 am ] |
Goof off works ok when there is just a little bit of stubborn gasket left. If it's the thick stuff I'd go with a torch and scraper. Even a fine wire wheel if some of it is a little stubborn. |
| Author: | Rust collector [ Thu Jul 29, 2010 1:56 pm ] |
Thanks! Uhm...I ended up squirting some gas on them, and put them on fire... Don't try this at home! Oh, they came off pretty easy after that. Guess I am going to town to get something safer now |
