| expected power gains? https://slantsix.org/forum/viewtopic.php?t=41195 |
| Author: | Brussell [ Mon Jul 26, 2010 7:10 am ] |
| Post subject: | expected power gains? |
Hi, I have a1967 VC and with a 225. Heads been ported and polished, and I want to shave the head abit to get the comp to 9.5:1, want to get bigger valves etc, car has a 2bbl 350 holley with aussie speed long runner intake and headders. brand new elec ignition with the module etc. Was also thinking of getting a more radical cam. What kind of power/ torque do you reckon I'd get? I am aiming for around 225hp. but what kinda of torque? With just the standard stall, and 3 spped 904tf and 3.89 diff gears do you reckon I could get 300+nm ? Thanks, also if you geniuses have any ideas of what I should or shouldn't do with this please tell me. NB: Did think of getting high comp pistons but none are avail here in Australia. Car is a street performance car/ daily driver. |
| Author: | Doc [ Mon Jul 26, 2010 8:55 am ] |
| Post subject: | Re: expected power gains? |
Quote: ... also if you have any ideas of what I should or shouldn't do with this, please tell me.
Don't put too much cam in it.... Car is a street performance car/ daily driver. Measure your current static and dynamic compression ratios. Select a cam that will support your intended RPM range, then match the static compression to give yourself an 8 to 1 DCR. DD |
| Author: | SV162 [ Tue Jul 27, 2010 12:07 am ] |
You may find you need a bit more stall than standard in the convertor. But then again......you may not. Sorry, that's not really helpful. |
| Author: | Dart270 [ Tue Jul 27, 2010 5:44 am ] |
All depends on your cylinder head. Cameron Tilley in Sydney (Manly, actually), could tell you where to get a good head made up, or he could maybe do it. I would mill/deck for 9.5:1 then get an Erson 280/270 cam or similar, and a 2600-2800 stall converter. It will feel like a stock stall until you stand on it. Lou |
