| Disc spindle bolt length https://slantsix.org/forum/viewtopic.php?t=41196 |
| Author: | MI6 [ Mon Jul 26, 2010 7:17 am ] |
| Post subject: | Disc spindle bolt length |
I'm just getting around to installing the disc brake spindles I picked up at the local yard. They are from a late 80s Diplomat and I'm installing them on my 71 Satellite. I ran into an issue with the bolts that attach the new spindle to the lower ball joint/steering arm. The original bolts are now too long and the bolts that came with the spindles are too short. I'm thinking of using some grade 8 bolts and nuts from the hardware store along with some locktite. Before doing this I'd like to know if grade 8 would be correct for this application or if someone has a better idea. Thanks. |
| Author: | Dart270 [ Mon Jul 26, 2010 10:20 am ] |
I have used grade 8 from the hardware store with no problems. Lou |
| Author: | MI6 [ Mon Jul 26, 2010 11:44 am ] |
That's good to know. I wasn't sure if grade 8 would be strong enough/too brittle etc. Wouldn't want the wheel assemble to head south while I'm heading north. Thanks. |
