| a 8-33 rebuild https://slantsix.org/forum/viewtopic.php?t=41210 |
| Author: | DadTruck [ Mon Jul 26, 2010 6:57 pm ] |
| Post subject: | a 8-33 rebuild |
I have picked up a set of A-833 trannys, one is an iron case unit, second is a aluminum OD. in evaluating the actual condition, 1) short of actually installing or disassembling the units is there a good test to determine condition? 2) I understand that both are units that are 35+ years old,,,,,to do a bench re build,,I am good with gauges, tools, is a realistic rebuild something I can do, or is this best left to a professional shop? 3) recomendations? photos:....... http://www.flickr.com/photos/13718356@N ... 465782267/ Other Notes: both are 26 spline inputs on the output the OD is a 23 spline output iron case is a 30 spline output how difficult will it be finding drive shaft yokes for each? thanks |
| Author: | DusterIdiot [ Mon Jul 26, 2010 7:06 pm ] |
| Post subject: | See Article section |
See Article section on Four Speeds at beginning of board. Quote: how difficult will it be finding drive shaft yokes for each?
26 spline is same as A904 yoke...29/30 spline is same as A-727...should find plenty under mopar cars or trucks of one kind or the other...-D.Idiot |
