It is currently Mon Jun 08, 2026 11:10 pm
 Post subject: NGK ZFR5N gap for 273
PostPosted: Mon Jul 26, 2010 9:40 pm
Does anyone have a suggestion for the appropriate plug gap for these plugs and 273?
Thanks,
Travis
69 Valiant Sygnet. 273 V-8
You're only as good as your last u-turn.
PostPosted: Tue Jul 27, 2010 4:55 am
In the early seventies when I had a 273 ci,. points type distributor equipped 67 Dart, the stock gap setting was 0.035â€￾.
If you have upgraded to a stock electronic ignition, you could set the gap at 0.040â€￾, and 0.045â€￾ if you have a MDS Blaster 2 coil or equal as these make a little more voltage over stock.
PostPosted: Tue Jul 27, 2010 7:11 pm
I'm still in catch up mode on this ride so I haven't had a chance to do the ignition upgrade. Thanks for the info.
Travis
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot] and 7 guests
