| NGK ZFR5N gap for 273 https://slantsix.org/forum/viewtopic.php?t=41214 |
| Author: | tgr23 [ Mon Jul 26, 2010 9:40 pm ] |
| Post subject: | NGK ZFR5N gap for 273 |
Does anyone have a suggestion for the appropriate plug gap for these plugs and 273? Thanks, Travis |
| Author: | wjajr [ Tue Jul 27, 2010 4:55 am ] |
In the early seventies when I had a 273 ci,. points type distributor equipped 67 Dart, the stock gap setting was 0.035â€. If you have upgraded to a stock electronic ignition, you could set the gap at 0.040â€, and 0.045†if you have a MDS Blaster 2 coil or equal as these make a little more voltage over stock. |
| Author: | tgr23 [ Tue Jul 27, 2010 7:11 pm ] |
I'm still in catch up mode on this ride so I haven't had a chance to do the ignition upgrade. Thanks for the info. Travis |
