It is currently Wed Jun 10, 2026 8:27 pm
 Post subject: first start in 11 years
PostPosted: Tue Jul 27, 2010 8:01 pm
okay guys i have a 225 and it hasnt ran is 11 years ran great but the last owner died and they left it in a garage what should i do before starting it.
I cleaned the plugs /changed oil / marvel mysterie oil in cylinders. anything else i should do before cranking it??
PostPosted: Tue Jul 27, 2010 8:07 pm
Fresh fuel...??
An officialis Tyrde-Browne Racing membrum
Fuel system,,,,at least drain the tank,change filter and hoses,clean out carb.
PostPosted: Tue Jul 27, 2010 8:39 pm
the whole truck is laying in my yard im using the frame and motor for my truck so when i try 2 start it just gas in the carb heres a pic what im starting it on haha im using all the the frame and motor for my 61 ford f350
PostPosted: Tue Jul 27, 2010 9:01 pm
6 Pack Dart
Heck I just used all the Ford stuff and put a slant six in it (about 25 years ago) and still drive it on the street and once in a while 1/4 mile it. :lol:
Richard
 Post subject: -
PostPosted: Wed Jul 28, 2010 9:57 pm
Take the oil filter off,and squirt plenty of oil in both the passages.Then rotate the engine 1/2 turn backwards,and juice it again,this will help prime the oil pump.
PostPosted: Thu Jul 29, 2010 12:31 am
Take the valve cover off and pour some oil over the rocker arms.
Pull plugs, and crank until you have oil pressure.
