| clattering rocker arm https://slantsix.org/forum/viewtopic.php?t=41227 |
| Author: | pathachmann [ Tue Jul 27, 2010 6:16 pm ] |
| Post subject: | clattering rocker arm |
Hello, one of my rocker arms is clattering, I think I have a stuck lifter, all the other 11 rocker arms are fine, can someone please guide me in the right direction in solving this issue. Thanks again Pat |
| Author: | slantzilla [ Tue Jul 27, 2010 6:52 pm ] |
If it's a solid lifter engine you just need to adjust it. There are multiple threads on here on valve adjustment. If it's a hydraulic motor you could have a bad lifter or worse. |
| Author: | Doc [ Wed Jul 28, 2010 9:00 am ] |
What year is the engine / vehicle? DD |
| Author: | pathachmann [ Sat Jul 31, 2010 9:10 am ] |
| Post subject: | How to fix a stuck lifter? |
It is a 1970 dodge dart 225 3.7L, I just put some kroil down in there, but if that doesn't work I need to know where to start thanks |
| Author: | VDART [ Sat Jul 31, 2010 9:30 am ] |
Search this forum for lifter adjustment--- -- pop the valve cover off & idle the motor--- check the movement of your rocker gear-- you'll have it purring in no time, Lawrence |
| Author: | Doctor Dodge [ Sat Jul 31, 2010 9:32 am ] |
Buy a valve cover gasket and then pull-off the valve cover and adjust the valve lash. The SL6 offered in 1970 has adjustable (mechanical) lifters / lash and those need occasional adjustment. DD |
