| first start in 11 years https://slantsix.org/forum/viewtopic.php?t=41230 |
| Author: | ebentraywick [ Tue Jul 27, 2010 8:01 pm ] |
| Post subject: | first start in 11 years |
okay guys i have a 225 and it hasnt ran is 11 years ran great but the last owner died and they left it in a garage what should i do before starting it. I cleaned the plugs /changed oil / marvel mysterie oil in cylinders. anything else i should do before cranking it?? |
| Author: | Mike'68Dart [ Tue Jul 27, 2010 8:07 pm ] |
Fresh fuel...?? |
| Author: | madmax/6 [ Tue Jul 27, 2010 8:07 pm ] |
Fuel system,,,,at least drain the tank,change filter and hoses,clean out carb. |
| Author: | ebentraywick [ Tue Jul 27, 2010 8:39 pm ] |
the whole truck is laying in my yard im using the frame and motor for my truck so when i try 2 start it just gas in the carb heres a pic what im starting it on haha im using all the the frame and motor for my 61 ford f350
| Author: | Fopar [ Tue Jul 27, 2010 9:01 pm ] |
Heck I just used all the Ford stuff and put a slant six in it (about 25 years ago) and still drive it on the street and once in a while 1/4 mile it. Richard |
| Author: | bigslant6fan [ Wed Jul 28, 2010 9:57 pm ] |
| Post subject: | - |
Take the oil filter off,and squirt plenty of oil in both the passages.Then rotate the engine 1/2 turn backwards,and juice it again,this will help prime the oil pump. |
| Author: | emsvitil [ Thu Jul 29, 2010 12:31 am ] |
Take the valve cover off and pour some oil over the rocker arms. Pull plugs, and crank until you have oil pressure. |
