| 8 1/4 limited slip https://slantsix.org/forum/viewtopic.php?t=41241 |
| Author: | hantayo13 [ Thu Jul 29, 2010 8:01 am ] |
| Post subject: | 8 1/4 limited slip |
need the tourque spec for ring gear,pinion and carrier housing thanks |
| Author: | DusterIdiot [ Thu Jul 29, 2010 5:56 pm ] |
| Post subject: | Per 1976 Manual |
Ring gear to diff case bolts -55 ft. lbs Drive Pinion Flange Nut - 210 ft.lbs. minimum Differential Bearing Cap Bolts - 100 ft. lbs |
| Author: | hantayo13 [ Fri Jul 30, 2010 5:38 am ] |
thank you |
| Author: | hantayo13 [ Mon Aug 16, 2010 9:46 pm ] |
thanks to all you guys...got the 4.10 limited slip in ....sure did wake up the 81 d150...also gain 5 mpg went from 10 to 15 yea , now on to engine keep on roddin' |
