| '66 Valiant - $? Collector for Duals-? https://slantsix.org/forum/viewtopic.php?t=4129 |
| Author: | WhaleMstr [ Fri Sep 06, 2002 11:58 am ] |
| Post subject: | '66 Valiant - $? Collector for Duals-? |
Howdy all, First, do you think $500 for a daily driving '66 Valiant is a good price? LOL (It's not a $200 non-running one!!) Going to look at it today and I will let you know what model and what condition it's in later. Second, what collector do ya use on homemade "Dutra Dual"? I am slowley starting to work on a set and was wondering where to get one and what to use? Thanks for any and all opinions! Later, Dan gramma@dm-tech.net |
| Author: | Doc. [ Fri Sep 06, 2002 12:46 pm ] |
| Post subject: | Re: '66 Valiant - $? Collector for Duals-? *PIC* |
: What collector do ya use on homemade : "Dutra Dual"? I am slowley : starting to work on a set and was wondering : where to get one and what to use? : : Thanks for any and all opinions! : Later, : Dan Flowmaster makes a nice "Y-Pipe" collector, order through Summit for a bit over $30.00 or just weld-up your own, I use pieces of old driveshaft tube as "raw materials". DD
| Author: | WhaleMstr [ Fri Sep 06, 2002 12:52 pm ] |
| Post subject: | Re: '66 Valiant - $? Collector for Duals-? |
Doc, that is a nice looking unit, but I screwed up. What I was looking for is the piece that actually gets welded to the front "dual" to bolt the collector to? Sorry for being a bit goofy! Thanks, Dan |
| Author: | Doc. [ Fri Sep 06, 2002 5:31 pm ] |
: Doc, that is a nice looking unit, but I screwed : up. What I was looking for is the piece : (outlet flange) that gets welded to the front : "dual" to bolt the collector to? : Sorry for being a bit goofy! : Thanks, : Dan For "homemade" front sections (or special rear sections) I use the stock cast iron factory outlet, (2 inch opening) cut from the stock manifold, relocated and welded onto the new location. DD Cut & Welded Exhaust Manifolds |
| Author: | WhaleMstr [ Fri Sep 06, 2002 7:08 pm ] |
| Post subject: | Thanks Doc - NM *NM* |
| Author: | Red [ Sat Sep 07, 2002 6:56 pm ] |
: For "homemade" front sections (or : special rear sections) I use the stock cast : iron factory outlet, (2 inch opening) cut : from the stock manifold, relocated and : welded onto the new location. : DD Doc, Have you tried the Lynx DCOE intake in the PIC? I've heard they don't work all that well, but would be curious to hear about your experience with it. ---Red |
