"Mopar VIN Decoder" says my 66 Dart has the 170 ci
https://slantsix.org/forum/viewtopic.php?t=41305
Author:  1966DartConvertible [ Mon Aug 02, 2010 8:22 pm ]
Post subject:  "Mopar VIN Decoder" says my 66 Dart has the 170 ci
I used this software off the internet here:
http://www.stockmopar.com/mopar-vin-decoder.php?
I punch in "LH27 A69 XXXXXXX" and it says "A" is the code for the smaller 170 slant six! My Reg Card clearly says "Engine Capacity = 3,687cc" which must be the 225 as the 170 is around 2,800cc.
Is there a way I could confirm which engine i have in the car? I mean difference between the 225 and the 170?
Appreciate any help! Thanx
Syed
Author:  Fopar [ Mon Aug 02, 2010 9:03 pm ]
Measure the hose that goes from the head to the water-pump, if it is about 3inches long it's a 225 if about 2inches long it's a 170.
Richard
Author:  ceej [ Mon Aug 02, 2010 9:57 pm ]
The engine has a stamp located here.
Once you've seen a 225 and a 170 side by side, you will know immediately! :D
CJ
Author:  1966DartConvertible [ Thu Aug 05, 2010 7:57 pm ]
Its OFFICIAL... she has the 170 :)
Engine number (under 1st spark plug) :
170 11 24
Casting number on the block (under the manifold)
2463230-1
PS: Anything more I can find out from these two set of numbers?
Cheers
Syed
