| ngk spark plug https://slantsix.org/forum/viewtopic.php?t=41321 |
| Author: | loops [ Wed Aug 04, 2010 1:41 pm ] |
| Post subject: | ngk spark plug |
are we sure that there is no interference with this long plug? |
| Author: | Aggressive Ted [ Wed Aug 04, 2010 1:55 pm ] |
Not sure which NGK's your referring to..... I use the NGK UR4GP/#2869 spark plugs in my 78 peanut plug head with no problems. Click on the red link below my name for pictures of the plugs after 55,000 plus miles. |
| Author: | Shaker223 [ Wed Aug 04, 2010 4:11 pm ] |
I use R5672A-10. no issues. |
| Author: | Joshie225 [ Wed Aug 04, 2010 5:08 pm ] |
| Post subject: | Re: ngk spark plug |
Quote: are we sure that there is no interference with this long plug?
Dozens of people with 225s have had zero problems with spark plug to piston interference with the extended tip NGK plugs.
| Author: | loops [ Wed Aug 04, 2010 5:56 pm ] |
| Post subject: | ngkzfr5n |
I am looking at a NGK zfr5n plug for my 73 225. Are we sure there is no interference? My parts guy is calling me nuts!!!!!!!!!!!!!! |
| Author: | ceej [ Wed Aug 04, 2010 6:03 pm ] |
As long as you aren't running zero deck it shouldn't be a problem. Is your engine modified? Stock the pistons will be down the hole .140 to .180" Lots of room. Gobs. The ZFR5N works great up to 8.5 or 9:1. Beyond that, it isn't a clearance issue, but a heat range issue. With 10.7:1 I run ZFR6-FIX-11 Iridiums, though they are not extended reach. As your compression exceeds 9.5:1 go colder. CJ |
| Author: | loops [ Wed Aug 04, 2010 6:25 pm ] |
| Post subject: | thanks |
AS ALWAYS........thanks to everyone! |
| Author: | Joshie225 [ Wed Aug 04, 2010 6:26 pm ] |
| Post subject: | Re: ngkzfr5n |
Quote: I am looking at a NGK zfr5n plug for my 73 225. Are we sure there is no interference? My parts guy is calling me nuts!!!!!!!!!!!!!!
Has your parts guy ever torn down a 225?
| Author: | BUCKET 636 [ Wed Aug 04, 2010 9:16 pm ] |
I just put them in my 225 a few weeks ago and no problems.
