| Can someone tell me if this is 170 or 225 Slant Six? https://slantsix.org/forum/viewtopic.php?t=41325 |
| Author: | 1966DartConvertible [ Thu Aug 05, 2010 12:44 am ] |
| Post subject: | Can someone tell me if this is 170 or 225 Slant Six? |
My engine: I know this engine is in need of TLC... and the carb is SOLEX(!) non-ori... and the brake master cyl is not original either...Oh Ignore the Yellow Motor Oil container (the fuel tank is full of sediments and rust)... but... Is this a 170 or 225? ![]() ![]() Cheers Syed |
| Author: | walpolla [ Thu Aug 05, 2010 1:22 am ] |
Hello, Impossible to tell from those pictures The search function is your friend, BUT, if you are unwilling to use it,look about 12 threads down this "Engine"page. You will no doubt find what you are looking for. This discussion has been discussed MANY times here. regards,Rod |
| Author: | 1966DartConvertible [ Thu Aug 05, 2010 1:26 am ] |
Quote: Hello,
..Impossible to tell from those pictures The search function is your friend, BUT, if you are unwilling to use it,look about 12 threads down this "Engine"page. You will no doubt find what you are looking for. This discussion has been discussed MANY times here. regards,Rod Ok will do... but... i've been told there are visual cues... such as shorter water pump hose(?)... But yeah will search for other threads... Cheers Syed |
| Author: | walpolla [ Thu Aug 05, 2010 1:43 am ] |
try here: http://www.slantsix.org/forum/viewtopic ... 170#280207 regards,Rod |
| Author: | 1966DartConvertible [ Thu Aug 05, 2010 7:53 pm ] |
Its OFFICIAL... she has the 170 Engine number (under 1st spark plug) : 170 11 24 Casting number on the block (under the manifold) 2463230-1 PS: Anything more I can find out from these two set of numbers? Cheers Syed |
| Author: | wjajr [ Fri Aug 06, 2010 5:04 am ] |
Yup, a 1965 170 ci. block. I recall you stating that your car was an early build 1966, so this is correct. |
