It is currently Sat Oct 10, 2026 12:30 am
 Post subject: Fuel Cell
PostPosted: Fri Jul 30, 2010 8:06 am
I have my fuel cell mounted in the car now. But I need some guidance on the venting. My cell has an outlet on the bottom and 2 fittings on the top. Are these both vents? Can they be tied together? And any special routing needed on the vent lines?
Thanks in advance, Rick
PostPosted: Fri Jul 30, 2010 4:03 pm
one is the return line for efi, that would be the one with the line going down into the foam. Just cap it off.
Will
 Post subject: Thanks
PostPosted: Fri Jul 30, 2010 8:05 pm
Ok Thanks Will. I sent you a PM too.
Rick
 Post subject: Is foam needed ?
PostPosted: Thu Aug 12, 2010 1:56 pm
Do I need to have foam in the tank? Mine does not have any.
Rick
PostPosted: Thu Aug 12, 2010 2:24 pm
Foam helps to reduce slosh and arrest fire, but it's not essential unless the track rules make it a requirement.
To me, and many sanctioning bodies, a fuel cell has a flexible bladder inside a metal can. The metal can can be punctured and not spill any fuel. Without the bladder it's just a fuel tank.
 Post subject: THanks Josh
PostPosted: Thu Aug 12, 2010 4:19 pm
Thanks Josh, and I understand. Mine is a gas tank. No bladder. :)
Rick
Users browsing this forum: No registered users and 18 guests
