| Transmission pressure port testing. https://slantsix.org/forum/viewtopic.php?t=41399 |
| Author: | emsvitil [ Tue Aug 10, 2010 11:30 pm ] |
| Post subject: | Transmission pressure port testing. |
What size threads are the test ports for the various pressure tests on the transmission case? FSM only mentions the mopar tool to use, not a generic equivalent. |
| Author: | Joshie225 [ Wed Aug 11, 2010 12:35 am ] |
The ports on the trans case look to be 1/8"-NPT. |
| Author: | Doc [ Wed Aug 11, 2010 8:35 am ] |
Be sure to use a pressure gauge that reads high enough, some of the test pressures are in the 200 to 300 psi range. DD |
