73' swinger
https://slantsix.org/forum/viewtopic.php?t=4143
Author:  matt gholson [ Sun Sep 08, 2002 6:58 pm ]
Post subject:  73' swinger
ignition starter screwed up ,has been hot wired ,need wiring diagram ,and how do i put the key switch back in ,as it is im hopping a yellow and red wire under dash while a jumper wire is coming off of battery to kill it i have to pull battery wire , HHHHelp I need to fix it before i sell it,
gholsonfour@msn.com
Author:  Doc. [ Mon Sep 09, 2002 9:53 am ]
Post subject:  Re: 73' Swinger Wiring Problem
: ignition starter screwed up ,has been hot wired
: ,need wiring diagram ,and how do i put the
: key switch back in ,as it is im hopping a
: yellow and red wire under dash while a
: jumper wire is coming off of battery to kill
: it i have to pull battery wire , HHHHelp I
: need to fix it before i sell it,
Most likley a starter relay or a bad nutural safty switch, runs some tests with a jumper wire or test light.
I will see if I have the schmatic, here is a link to an earler Darts under dash wiring.
64 Dart Under Dash Wiring
