It is currently Sat Jun 20, 2026 7:55 pm
 Post subject: Float for my Holley 1920
PostPosted: Sun Aug 15, 2010 5:34 pm
After hearing horror stories about crappy reman carbs from parts places and having nothin but problems with my carb since I put it on, I decided to tear it down. Sure enough, there is a hole in my float. I have a Holley 1920 on a 72Duster /6 in my 82 dodge truck. Where can I get this float and which one do I need? Walker shows 2 but I dont know which one to get. Thanks
PostPosted: Sun Aug 15, 2010 10:07 pm
Go to the Engine FAQ and look up the carb info. SL6 Dan has listed the float on several different posts if you just want to use the search function, that's another option. You can also by them from Joe's Carb Shop in Lynnwood, WA, look under Slant Six Network for their number.
I have used both, the stock red one and the sealed black one. Both work fine. I am running the black one at the moment.
PostPosted: Mon Aug 16, 2010 5:45 am
I agree, I should've have searched around first but I was posting from my phone and it is hard for me to see. Thanks for the info. Now that I'm on my computer, I've already found the info that I was looking for.
