Records?
https://slantsix.org/forum/viewtopic.php?t=41493
Author:  Rick Covalt [ Wed Aug 18, 2010 8:59 am ]
Post subject:  Records?
Would it be possible to place the records page for the 1/8 and 1/4 miles in this section as a sticky? I know some are planning to set some new records shortly and it may be good to have them here on the site for all to see. Also the rules for setting those records on the same sticky would be great.
Rick Covalt
Author:  Doc [ Wed Aug 18, 2010 10:04 am ]
If someone starts the message thread, we can make it a sticky.
Author:  Rick Covalt [ Wed Aug 18, 2010 10:11 am ]
Post subject:  ??
Doc,
Is it possible that someone can pull the records page off of one of the SSRN and post it. Or does all that info have to be entered individually?
Rick
Author:  madmax/6 [ Wed Aug 18, 2010 9:45 pm ]
How do I start the message thread?I am one going for a record.Guzzi Mark
Author:  Doc [ Thu Aug 19, 2010 8:26 am ]
Post subject:  Re: ??
Doc,
Rick
We could post images of the rules and the current list of records out of past SSRN news letters and then someone will need to do up-dates as new records / changes occur.
I will scan the SSRN sheets and post to see if the quality is OK.
Author:  ryandcovalt [ Thu Aug 19, 2010 8:38 pm ]
Doc,
I tried to copy and paste the records into the sticky. I basically used a copy of a screenshot and posted it. I think it turned out ok. I thought it would be ok to start with, until someone has time to scan or type out the records.
Author:  Dart270 [ Fri Aug 20, 2010 2:13 am ]
Thanks guys!!
Author:  Charrlie_S [ Fri Aug 20, 2010 4:47 am ]
Just looking over the SSRN issue 50. Barry Harrison set a 1/8 mile "B" Nitrous record at Farmington, that is not listed, in the records page. He turned a 6.89 at 99.59 mph. The backup, however was only a 7.41, but that is still a record.
Author:  ryandcovalt [ Fri Aug 20, 2010 6:56 am ]
The rule says the back-up run has to be within 1%, but the slower time would still count for the record correct? We can add that to the sticky if so.
