Disc Brake Upgrade Seals
https://slantsix.org/forum/viewtopic.php?t=41514
Author:  FrankRaso [ Thu Aug 19, 2010 8:57 am ]
Post subject:  Disc Brake Upgrade Seals
I'm slowly upgrading the brakes on my 65 Barracuda from 9" drums to disc brakes from a 74 Duster. Before mounting the power brake booster on my Barracuda, I thought I would clean them up and give the brackets a coat of paint.
Now that I have everything apart, I see that the Duster's gaskets and seals are shot. I would like to replace the following items:
  • Firewall Gasket (square shape with 4 bolt holes)
  • Brake Pedal Push Rod Grommet (fits inside plate over firewall gasket and seals the push rod
  • Power Brake Booster Boot (seals the booster's push rod
I see that a number of places have firewall gasket kits but I could just use the above 3 items. I could also make the firewall gasket if but these gaskets seem fairly inexpensive. Any suggestions as to where I could get these parts?
Also, between the booster and the master cylinder, there's a spacer with a plastic insert. Under the plastic insert appears to a foam filter, presumably to keep the dust out of the bellows in the booster. Any recommendations for what type of foam I could use to replace this part?
Author:  wjajr [ Thu Aug 19, 2010 9:23 am ]
Check with Detroit Muscle, they make all sorts of body gaskets for our cars. Perhaps they can send you just the few that you need.
