| Newer model carb swap-out? https://slantsix.org/forum/viewtopic.php?t=41530 |
| Author: | rd [ Fri Aug 20, 2010 10:02 am ] |
| Post subject: | Newer model carb swap-out? |
My old carb is pretty much junk. Is there a newer model anything that would fit a 1975 dodge slant 6 engine ? It has a 1 bbl Holley 1920, I believe, right now . (numbers I found---12R-4285B and 6260 2 2135 . I hate to rebuild it again. Maybe something I can pull at the auto salvage. Thanks |
| Author: | rustyfords [ Fri Aug 20, 2010 11:30 am ] |
The 1969 Dart 225 that I swapped into my '76 Valiant had a 1920 on it, and it was a bit worn out as well. However, it was a good, rebuildable unit and I decided to keep and rebuild it with a Walker kit. It turned out great and I'm glad I kept it. In fact, I was on the interstate with it about an hour ago (in Houston no less), keeping up nicely with the surrounding traffic. I guess you could go with a 1945, but you'd have to tweak some of the connections here and there, and I could be wrong, but I don't think you'd gain a lot over a quality rebuild on the 1920. As an aside...my 1920 rebuild took me all of about two hours...and that's only because I had zero experience with it. If I have to do another one, I bet I can lick it in half the time. |
