Small Block Converter on a slant??
https://slantsix.org/forum/viewtopic.php?t=41558
Page 1 of 1
Author:  805moparkid [ Sun Aug 22, 2010 10:11 am ]
Post subject:  Small Block Converter on a slant??
i read somewhere that a small block 904 converter will work on a /6 904?
Author:  Charrlie_S [ Sun Aug 22, 2010 10:17 am ]
Post subject:  Re: Small Block Converter on a slant??
Yes they will fit, as long as you use a 65-67 V-8 converter on a 60-67 trans, or a 68 up converter on a 68 up trans. The stall speed may or may not be correct, by a couple of hundred rpm. Also a 360 converter would need the weights removed. One other thing a lockup or non lockup converter must be used with the correct lockup or non lockup trans.
Author:  805moparkid [ Sun Aug 22, 2010 10:23 am ]
really! cool! so the small blocks have the same deal with the torque converter hubs? and i need a 3K converter so i'll have to find out what the cnverters are rated at...
thx
Author:  slantzilla [ Sun Aug 22, 2010 2:49 pm ]
In a stock application the Slant and 318 get the exact same converter.
In the aftermarket, reduce the rated stall for a small block by around 400 RPM for a Slant application as a general rule.
Author:  805moparkid [ Mon Aug 23, 2010 9:47 pm ]
running about 220hp and 250tq. 400 rpm difference still a good range?
thx
Author:  bigslant6fan [ Mon Aug 23, 2010 10:02 pm ]
Post subject:  -
I disagree with S/6 and 318 converters being exactly the same one.The 318 one behind a S/6 will stall 200-300 RPMs lower than the OEM S/6 one.I've put quite a few S/6 converters behind 318s for a "free" performance trick,including my daily driver.
