| Sticking starter - Best Starter source? https://slantsix.org/forum/viewtopic.php?t=41559 |
| Author: | cw6er [ Sun Aug 22, 2010 11:03 am ] |
| Post subject: | Sticking starter - Best Starter source? |
Started the truck the other day and when I released the key I could still hear that rather unique "whanging" sound of a Chrysler starter churning away!! Luckily I had the small tool box on the floor and grabbed a pair of vise grips and was able to wrestle the ground cable off of the battery before the battery ran down, or the starter was damaged or shorted out and caught fire ..... which was an extremely good thing, as I was sitting next to the gas pumps at the time!! Hmmm .... was it a bad Start Relay sticking or bad Starter Solenoid sticking? Well, I got it home and started it a couple of times and the next time it did it I pulled the plug on the Start Relay and it continued to crank, so it must be a Starter Solenoid sticking, but are the contacts welding or the pull-in mechanism not releasing .... Hmmm So now I am trying to figure my options.
What is the correct grease to use in the pull-in/clutch mechanism? ______________________________________________ Here is the style of starter on the truck ($50 Reman): <img src="http://contentinfo.autozone.com/znetcs/additional-prod-images/en/US/dur/DL3257/4/image/4/"> There is a Brush/Solenoid contact piece that is available ($33): <img src="http://contentinfo.autozone.com/znetcs/additional-prod-images/en/US/wl2/CX12H/2/image/4/"> |
| Author: | shadetree [ Sun Aug 22, 2010 3:08 pm ] |
| Post subject: | stuck starter |
NAPA IS A GOOD SOURCE. Just pay the higher price for the better part. I would shop locally for a rebuilder.Better odds of getting a good rebuild but it will take time. Asking around for quality. Even if you buy rebuilt do this for next time. Disk brake wheel bearing grease is what I use. If you do rebop it yourself buy the brush fixture you pictured. Also GENTLY polish the armature end before you install brushes. Change the bendix unit [ starter drive]. See if you can get the washer for the armature end.If your first time at this find a PAL to aid you or you will go NUTS. my words shadetree |
| Author: | Pierre [ Sun Aug 22, 2010 9:37 pm ] |
Search for "nippondenso starter" or "mini starter" for more info on the modern later style unit. |
| Author: | carlherrnstein [ Mon Aug 23, 2010 1:07 pm ] |
I went to a salvage yard and asked for a starter for a 98 dodge dakota with the 3.9 v6. I had to work on the solinoid wire contact but that wasn't to bad. I got it for $10 and, I have instant starts most of the time |
| Author: | Wesola78 [ Tue Aug 24, 2010 6:35 am ] |
I have a reman starter for a '93 Dakota with a V6. It's been working fine. I second the idea of finding a local rebuilder for your starter. |
