| low charge? https://slantsix.org/forum/viewtopic.php?t=41664 |
| Author: | oo3 [ Sun Aug 29, 2010 2:25 pm ] |
| Post subject: | low charge? |
66 a100 with original type single field wire alt - at idle i recently measured 12.5 volts on bat and also at bat terminal on alt - increase the rpms and i do get up to the 13.5 close to 14v range - with a load ( headlights ) and rpms up it dips just a bit but still stays up close to 13.5 - i went ahead and replaced the alt ground to regulator wire and also the alt field to regulator wire - it basically stayed the same - is this range of idle voltage typical for a single field type circuit or do i have a charging problem - i cant recall ever making this measurement since i have had the van ( app 3 years ) so i do not have a previous to compare it to with this vehicle - oo3 |
| Author: | emsvitil [ Sun Aug 29, 2010 2:27 pm ] |
The original low amp alternators will do that. If it's a point regulator, you can tweak the adjustment to raise the voltage when it's above idle speed. |
| Author: | oo3 [ Mon Aug 30, 2010 5:22 pm ] |
thanks - puts my mind at ease until i can upgrade to a dual field system - oo3 |
