| thunder bird housing location https://slantsix.org/forum/viewtopic.php?t=4169 |
| Author: | andrew [ Fri Sep 13, 2002 12:51 pm ] |
| Post subject: | thunder bird housing location |
To anyone that is going to use the thunderbird turbo. You are going to have too keep the intake housing within a 1/4 turn from stock. The turbos do not have a 360 degree thrust bearing and I havebeen going thru oil seals because of this. just something to think about!!!! andrew wagner |
| Author: | Doctor Dodge (Doug Dutra) [ Sun Sep 15, 2002 9:35 am ] |
| Post subject: | Re: thunder bird housing location |
: To anyone that is going to use the thunderbird : turbo. You are going to have too keep the : intake housing within a 1/4 turn from stock. : The turbos do not have a 360 degree thrust : bearing and I havebeen going thru oil seals : because of this. : just something to think about!!!! : andrew wagner Thanks for this tip Andrew, I am kinda spoiled with the 2.2 TO3s, I spin the housing around many different ways on those with the only limit being where you can remount the waste gate pull-off diapham. Hows the Turbo business going? It's reall a tough time to try to start a business, no-one seem to have much extra $$ these days. (including me : - ( DD |
