It is currently Tue Jun 23, 2026 5:52 am
PostPosted: Fri Sep 13, 2002 12:51 pm
To anyone that is going to use the thunderbird turbo. You are going to have too keep the intake housing within a 1/4 turn from stock. The turbos do not have a 360 degree thrust bearing and I havebeen going thru oil seals because of this.
just something to think about!!!!
andrew wagner
PostPosted: Sun Sep 15, 2002 9:35 am
: To anyone that is going to use the thunderbird
: turbo. You are going to have too keep the
: intake housing within a 1/4 turn from stock.
: The turbos do not have a 360 degree thrust
: bearing and I havebeen going thru oil seals
: because of this.
: just something to think about!!!!
: andrew wagner
Thanks for this tip Andrew, I am kinda spoiled with the 2.2 TO3s, I spin the housing around many different ways on those with the only limit being where you can remount the waste gate pull-off diapham.
Hows the Turbo business going? It's reall a tough time to try to start a business, no-one seem to have much extra $$ these days. (including me : - (
