741 case question
https://slantsix.org/forum/viewtopic.php?t=41701
Author:  plymouth6 [ Tue Aug 31, 2010 3:47 pm ]
Post subject:  741 case question
Is a 741 case ok to use for a turbo drag car build? I know it has a smaller bearing so this is why I am questioning it. I will also be running a spool.
Author:  wagonmaster [ Tue Aug 31, 2010 4:03 pm ]
Yes,in my opinion it is a very durable setup it has a 1 3/8" pinion shaft,that`s bigger than most other brands heavy duty stuff, you may find a limited selection of gear ratios avaliable, 3.73 and 3.91 are available from randy`s ring and pinion, if you want a lower ratio you may look into a 742 or 489 case.
But if it is set up correctly,you`d be hard pressed to damage a 741.
Author:  turbo66valiant [ Wed Sep 01, 2010 4:14 pm ]
Hey,
I run the 741 case in mine with stock axles. Later
Ryan
Author:  65 dartman [ Wed Sep 01, 2010 5:39 pm ]
Back in the day, they used the 741 (and Ball and Trunnion) with Max Wedges. It'll hold up.
Author:  plymouth6 [ Wed Sep 01, 2010 7:49 pm ]
Thanks a lot guys for the info now i need to find some 2.73 gears for it. I have 3.55s and they are to low for me.
Author:  Joshie225 [ Wed Sep 01, 2010 7:53 pm ]
There are 2.76s available. I wish I had known you had 3.55s. I would have traded for my 2.76s, but I sold them a week ago.
Author:  plymouth6 [ Wed Sep 01, 2010 9:41 pm ]
Day late dollar short. The story of my life :lol:
Author:  Joshie225 [ Wed Sep 01, 2010 9:43 pm ]
Would you like to sell the 3.55 third member? Trade for 3.23s and some cash? I would have been able to offer 2.94s, but they are gone too.
Author:  bigslant6fan [ Wed Sep 01, 2010 10:15 pm ]
Post subject:  -
741 3.91 gears from a junk yard rear made about 100 passes in my dad's 13 flat 340,4 speed '67 cuda-and we changed it to a 4.10 742 case.Then we put the 741 in a 300HP 360 "farm truck" that we've towed a 12,000 GVW. gooseneck for about 50,000 miles.
Author:  slantzilla [ Thu Sep 02, 2010 4:39 pm ]
I ran a 3.91 SG 741 in my '66 forever. It went 12.0's and never hurt anything. :D
Author:  plymouth6 [ Thu Sep 02, 2010 5:44 pm ]
Well all of this is good to know I dont have to worry anymore. Thank you very much guys... Raymond
