| Engine volumes for CR Calculation to match Erson RV15 https://slantsix.org/forum/viewtopic.php?t=41710 |
Page 1 of 2 |
| Author: | Adrenalin [ Wed Sep 01, 2010 10:35 am ] |
| Post subject: | Engine volumes for CR Calculation to match Erson RV15 |
Dear All, At last I am installing my cam to my Slant. I was told by the gurus to measure the Static CR and work till it is 9.0:1. Today I have measured and it is as fallows: Combustion Chamber: 56 cc Piston Dish: 13.346 cc Piston Deck Clearance: 0.1574" (4 mm) Compressed Head Gasket: 0.035" (0.9 mm) Head Gasket Bore Diameter: 3.476" (88.3mm) Cylinder Bore: 3.425" (87mm) Stroke: 4.124" (104.77 mm) With this values I calculate 7.2:1 CR... where did I go wrong? I measured the combustion chamber by syringe, ok it is not precise but that much? There should be something wrong, heeeelp!!!! |
| Author: | Shaker223 [ Wed Sep 01, 2010 10:43 am ] |
Based on the info you provided, I come up with: 7.32 |
| Author: | Adrenalin [ Wed Sep 01, 2010 10:57 am ] |
Quote: Based on the info you provided, I come up with: 7.32
exactly... and I have shaved 0.047" from my head before cam installation. (which I thought it would be safe without cam)The doc told me RV15M needs 9:1 CR. Even if I use a flat head piston and shave 0.1" (47 cc chamber) more it will be just 7.86:1. I guess I am missing something... |
| Author: | Adrenalin [ Wed Sep 01, 2010 11:00 am ] |
shaving 0.1" from the head should delete 14.87 cc from the chamber. If we accept its 58 cc than there should be 43 left. and it just makes 8.18:1. My piston dish volume is 13.346 cc, is it possible that I miscalculated it? |
| Author: | Doc [ Wed Sep 01, 2010 11:17 am ] |
Quote: Piston Deck Clearance: 0.1574" (4 mm)
This number is suspect.Are you saying that the pistion is -.1574 "down" in the cylinder? When using a "metric" type piston (2.2 family) and a 7 inch c to c con rod, piston deck height should end-up near zero. DD |
| Author: | Adrenalin [ Wed Sep 01, 2010 11:20 am ] |
| Author: | Doc [ Wed Sep 01, 2010 11:30 am ] |
So... what pistons do you have and what connecting rod? DD |
| Author: | Adrenalin [ Wed Sep 01, 2010 11:40 am ] |
Quote: So... what pistons do you have and what connecting rod?
well, I do not know.. they do have 13.346 cc dish on them... how can I identify a slant 6 piston?
DD |
| Author: | Doc [ Wed Sep 01, 2010 11:53 am ] |
Let's back-up another step and get some history on what you are working with. Is this an old engine that you are changing a cam on or is this a "rebuilt" engine where parts have been replaced? If this is a older "factory" engine, give us year & modle of the vehicle. Is this an "export" vehicle / engine? (lower compression) What fuel is avalable in your area? DD |
| Author: | Adrenalin [ Wed Sep 01, 2010 12:04 pm ] |
Quote: Let's back-up another step and get some history on what you are working with.
Ok, I have a Dodge power wagon truck but previous owner swapped the original V8 engine with a slant6. I live in Turkey and in Turkey we have a chrysler factory which produced many 2wd pickups with slant six. My engine serial number is 76C2252328 (if it means anything) so I do not know which year it is (is it 1976? Is this an old engine that you are changing a cam on or is thai a "rebuilt" engine where parts have been replaced? If this is a older "factory" engine, give us year & modle of the vehicle. Is this an "export" vehicle / engine? (lower compression) What fuel is avalable in your area? DD |
| Author: | Adrenalin [ Wed Sep 01, 2010 12:13 pm ] |
<a href="http://s622.photobucket.com/albums/tt309/adrenalin_photo/?action=view¤t=PA300126.jpg" target="_blank"><img src="http://i622.photobucket.com/albums/tt309/adrenalin_photo/PA300126.jpg" border="0" alt="Photobucket"></a> this is my deck which you can see the unswept cylinder wall of 4 mm. |
| Author: | Doc [ Wed Sep 01, 2010 12:15 pm ] |
OK, looks like we have an "export" engine built w/ low compression pistons. To get 9 to 1 static compression and 8 to 1 dynamic compression ratio, change to flat top pistons and set the combustion chambers at 48 cc. Can you give us the measurments of the piston dish? (diameter and depth of the dish) |
| Author: | Adrenalin [ Wed Sep 01, 2010 12:15 pm ] |
<a href="http://s622.photobucket.com/albums/tt309/adrenalin_photo/?action=view¤t=PB140117.jpg" target="_blank"><img src="http://i622.photobucket.com/albums/tt309/adrenalin_photo/PB140117.jpg" border="0" alt="Photobucket"></a> my steel (not aluminum) head.. polished by me. |
| Author: | Adrenalin [ Wed Sep 01, 2010 12:16 pm ] |
<a href="http://s622.photobucket.com/albums/tt309/adrenalin_photo/?action=view¤t=PB140132.jpg" target="_blank"><img src="http://i622.photobucket.com/albums/tt309/adrenalin_photo/PB140132.jpg" border="0" alt="Photobucket"></a> full view of my steel cylinder head |
| Author: | Adrenalin [ Wed Sep 01, 2010 12:18 pm ] |
Quote: OK, looks like we have an "export" engine built w/ low compression pistons.
Lower diameter 54 cm (2.1259")To get 9 to 1 static compression and 8 to 1 dynamic compression ratio, change to flat top pistons and set the combustion chambers at 48 cc. Can you give us the measurments of the piston dish? (diameter and depth of the dish) Upper Diameter 63 cm (2.48") Height: 5 mm (0.196") It is a Frustum... |
| Page 1 of 2 | All times are UTC-07:00 |
