| Has this ever happened to you ??? https://slantsix.org/forum/viewtopic.php?t=41765 |
Page 1 of 2 |
| Author: | apairof66s [ Sun Sep 05, 2010 7:04 am ] |
| Post subject: | Has this ever happened to you ??? |
Recently had tires replaced on the 64 Dart. Told them it had left handed threads and sure enough when it came time to replace the front brake shoes the wheel studs are spinning on the hub. Left front has two that I can get the lug nuts off of. Standard 9 in. drums, 14 in. Cragar SS wheels w/ the small bolt pattern. I really don't want to destroy the wheel to get it off. any HELP ??? |
| Author: | kesteb [ Sun Sep 05, 2010 9:31 am ] |
Remove the whole assembly by removing the front bearing retainer. Chisel or grind the back of the studs off and then replace the studs and or the whole spindle/drum assembly. Then send a bill to the tire store... |
| Author: | apairof66s [ Sun Sep 05, 2010 9:23 pm ] |
On the Cragar SS wheel the centercap is bolted on from the backside..... |
| Author: | GTS225 [ Mon Sep 06, 2010 4:47 am ] |
Dremel tool and carbide bits.......cut the lug nuts in half to get them off. OH....wait.....the Crager SS uses a shank type lug nut. Looks like it's grinder time. You MIGHT be able to find somebody that's good with a cutting torch that can take the tops off the lug nuts without damaging the rim. Don't EVER go to that tire shop again. Roger |
| Author: | Kidd [ Mon Sep 06, 2010 9:30 am ] |
That happend to me one time w/ my Road Runner.Take off all the nuts you can....Then let the jack down till most all the weight is on the side of the studs that were spinning.if you can get the weight to hold the studs sideways enough, you can get the nuts started. When I bought my Barracuda, the same thing must have happened to the last owner, cuz when I took off the drivers front, the studs all had weld globs holding them from spinning.LOL Good luck!! Andrew/kidd |
| Author: | Charrlie_S [ Mon Sep 06, 2010 4:08 pm ] |
Wrong. Go to that shop, again. Tell them to repair the problem.
Roger |
| Author: | apairof66s [ Wed Sep 08, 2010 2:41 am ] |
Thanks for all the replies. I will try to loosen the lug nuts with the weight of the tire & wheel on the ground. I will post the results in a couple of days. The left front wheel has only a couple of lug nuts that are keeping it on the car so I can't drive it back to the tire shop. As much as I'd like to show them what they've done it's just not worth it to cause further damage right now. |
| Author: | Kidd [ Tue Sep 14, 2010 9:48 pm ] |
well......did it work? Hope so!! Kidd/Andrew |
| Author: | 2 Darts [ Wed Sep 15, 2010 9:35 am ] |
| Post subject: | 2¢ worth |
I'm with Charrlie_S to the extent that you should not let the shop off the hook. I had a problem with an NTB shop who broke off studs and ended up screwing up the front brake drums (10") in an attempt to fix the problem. The brake drum issue didn't show up until a couple of months later in the form of radial cracks around the outside of the drum. I wrote the store a letter detailing my experience and followed it up with a phone call a few days later. The manager asked to see the drums, which I took to the store that day. He agreed with the damage issues I raised. They were unable to find the drums locally, but offered to re-imburse me for the cost of drums if I could find them (within reason). It took a few days, but I found a pair. I had new studs fitted to the hubs and the drums swaged on by a machine shop. The NTB store paid the bill. From the experience, I learned NEVER let anyone with an impact hammer go near the driver's side of my Mopar if it has LH studs. People have gotten upset with me until they see how it works for themselves. No one wants to brake a stud off if they can avoid it. |
| Author: | apairof66s [ Wed Sep 15, 2010 12:55 pm ] |
| Post subject: | live & learn |
As luck would have it we got the lug nuts off. We put two pry bars behind the spokes of the wheel and was able to get the two off. We inspected all of the stud holes in the hub and most of them are smoothed out. Then we had all the studs welded to the hub mostly because replacement hubs are scarce. I wasn't my first choice but the Dart had to be moved to make way for another project............... |
| Author: | militos [ Fri Nov 12, 2010 4:29 pm ] |
waith just a minute,,,so you guys are say ing that somewere in the car driver side the studs are left treaded?? please gime more details about this, what years for example?? is this a manufacturing recomendation?? you can just go to the store/shop and say,,hey,,I want only right tread studs in my Dodge!! there must be a reason of why they do that left tread thing. thanks. |
| Author: | Fopar [ Fri Nov 12, 2010 5:11 pm ] |
Clean off the ends of the studs if they have a "L" they are left handed thread. Richard |
| Author: | emsvitil [ Fri Nov 12, 2010 6:18 pm ] |
Quote: Clean off the ends of the studs if they have a "L" they are left handed thread.
Richard What about a "7" ? |
| Author: | Fopar [ Fri Nov 12, 2010 6:22 pm ] |
Ed I want to sell you the "710" cap for your motor Richard |
| Author: | militos [ Fri Nov 12, 2010 8:09 pm ] |
yes,,I will clean the outer ends of the studs, But, is there a reasn of why they are left treads on those studs?? |
| Page 1 of 2 | All times are UTC-07:00 |
