| Axleshaft Interchange https://slantsix.org/forum/viewtopic.php?t=41784 |
| Author: | Old Car Scott [ Mon Sep 06, 2010 6:32 pm ] |
| Post subject: | Axleshaft Interchange |
Can the just the axleshafts be swapped between A-body Mopar 7 1/4" rear ends somewhat easily, or would it be easier to swap the entire rear axle? I have a '67 Valiant with the SBP 7 1/4 and was looking at options of swapping to the larger bolt pattern on the rear. I found a '74 Dart 7 1/4" rear somewhat locally with the big bolt pattern, but I'm not sure if they interchange. |
| Author: | Joshie225 [ Mon Sep 06, 2010 6:39 pm ] |
To go from small bolt pattern to large you have to swap the whole axle assembly. The shafts do not interchange. We discussed this recently. http://slantsix.org/forum/viewtopic.php?p=287053 |
| Author: | bigslant6fan [ Mon Sep 06, 2010 6:51 pm ] |
| Post subject: | - |
Josh is right,The Mopar performance book that says this can be done is wrong. |
| Author: | Old Car Scott [ Mon Sep 06, 2010 9:12 pm ] |
Thanks guys!! I'm glad I asked first!! |
