| Intake/Exhaust stud specs? https://slantsix.org/forum/viewtopic.php?t=41844 |
| Author: | Porter [ Fri Sep 10, 2010 8:30 am ] |
| Post subject: | Intake/Exhaust stud specs? |
I sent my head to a shop to get reconditioned and they had to remove my intake and exhaust manifold studs to fit the seat and guide machine. When I went to pick it up, the studs had been pitched. I know I can get these studs included in the ARP head stud kit, but I don't want to use head studs. I just want to know the lengh of the studs and how much thread is on each side of the shank. Any help would be appreciated. Thanks, John |
| Author: | Wesola78 [ Fri Sep 17, 2010 4:22 am ] |
I'm not sure, but the last time I replaced the intake/exhaust manifold gasket, the studs looked to be sticking out about an inch and a half, more or less. On the threads, I would guess that they go from the tip of the stud almost to the head. |
| Author: | Wesola78 [ Fri Sep 17, 2010 4:23 am ] |
Oh yeah, I read here somewhere that carb studs are the same as slant six intake/exhaust manifold studs. |
| Author: | 66aCUDA [ Fri Sep 17, 2010 8:08 am ] |
Reed had this same question about a month ago. See if he found a solution. Frank |
| Author: | Doc [ Fri Sep 17, 2010 12:38 pm ] |
Manifold set to Cylinder Head Studs are 5/16-18 unc x 1/2" thread length (head side) by 5/16-24 unf x 3/4" manifold side. The factory stud was 1 7/8" in total length so there was about 5/8 inch of unthreaded area between the two threaded ends. Many of today's replacement "aftermarket" studs are either a little long (2 inch total) or a little short. (1 3/4" total) The thickness of the "spanner washers" to be used, will help decide on which stud to get. The machine shop that "tossed" yours, should get you a set of replacements. DD
| Author: | Porter [ Sun Sep 19, 2010 10:46 am ] |
Thanks, I found a set specifically for slant six manifolds at www.silver-seal.com. 1.88 inches long... PN 6403... 8 bucks. |
| Author: | slantzilla [ Wed Sep 22, 2010 2:58 pm ] |
Quote: Thanks,
I just tried to order through their website and couldn't. Called the toll free number and the lady said I was her 5th complaint today. I just ordered over the phone. 36 studs @ .50 each. I found a set specifically for slant six manifolds at www.silver-seal.com. 1.88 inches long... PN 6403... 8 bucks. Thanks for the link! |
| Author: | Porter [ Fri Sep 24, 2010 4:59 am ] |
You are very welcome! |
| Author: | slantzilla [ Sun Sep 26, 2010 8:30 am ] |
Studs were in the mail yesterday. I would call that great service. |
