It is currently Mon Oct 12, 2026 5:51 pm
 Post subject: Hei Coils
PostPosted: Sun Sep 12, 2010 4:48 pm
JUST WONDERING WHICH COIL IS BEST AND WHY,
SMALL GM COIL VS HUGE FORD COIL FOR THE MIGHTY SLANT TO USE,
AND MAYBE U GUYS COULD POST SOME PICS OF YOUR SET UP,
THANK YOU, JASON
PostPosted: Sun Sep 12, 2010 7:02 pm
Hi Jason, this is a subject with lots of input, you should click on the red text to follow the links in the electrical section - Frequently Asked Questions - Electrical, you will find all the info you need there.
Olaf
Aspenized
PostPosted: Sun Sep 12, 2010 9:55 pm
I just added a new picture of the 3 ohm Pertronix HEI coil I am using. I took out the ballast resistor so it gets a full 12 volts. I am still running my old orange MOPAR ECU. Click on the red link below my name to view pictures of the coil. They are at the end of the slide show. Double click for full screen mode.
The plugs stay very clean and are gaped at .045.
