It is currently Thu Nov 26, 2026 6:20 am
 Post subject: crankshaft bearings
PostPosted: Tue Sep 21, 2010 5:38 am
Can I change bearings just remove the oil pan? With out removing the engine.
Satellite Wagon'72
PostPosted: Tue Sep 21, 2010 6:04 am
Я самый счастливый человек на свете! Весь день камень на душе, что дико стучит у плимута под капотом. А это блядь вентилятор хуячит по патрубку. Оттянул радиатор и мотор вновь заработал неслышно. Ей богу, самый счастливый человек в галактике.
Satellite Wagon'72
PostPosted: Tue Sep 21, 2010 6:26 am
Site Admin
In an A-Body that would be pretty much "no."
You might have clearance to remove the pan and do this in the Satellite. I don't know.
There are a couple of reasons you won't want to do this.
1. It is a miserable job spent spitting old motor oil and cleaning it off your safety glasses so you can see what your doing.
2. Sealing the pan effectively is best done with the engine upside down on a stand.
If you find you have room to remove the pan and do this work, let us know how it goes. I accomplished this job once on a BB in a truck. It was the least enjoyable hobby-wrenching experience I've had to date. And that was over 20 years ago. :shock:
2¢
CJ
PostPosted: Tue Sep 21, 2010 10:22 am
It can be done in a B body..I did it myself once. Took two days, including the rear main seal. That being said, I'm not an ace mechanic, but I know what I'm doing... Do you? Not something a novice should try.
PostPosted: Tue Sep 21, 2010 12:07 pm
I've changed rod bearings in a 70 a body /6 but did not attempt the main bearings.
11.02 @ 120.56
Chassis dyno
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 7 guests
