| Converter & Gear choice. https://slantsix.org/forum/viewtopic.php?t=41906 |
| Author: | drgonzo [ Wed Sep 15, 2010 10:34 am ] |
| Post subject: | Converter & Gear choice. |
OK, here is where my 'figerin' has got me so far: '63 dart, full interior, street car. 904/225 Right now it has an open 7.25 of undetermined ratio. I also have a narrow (57-59 ford) 9 inch with 3.55 gears. What converter would work well with the 3.55 gears and this engine combination? Feel free to comment, critique or otherwise, it's all good. 225 9:1 CR "Good" valve job, bowl and port clean up and ports matched. Erson RV15 Cam H-Pak 450cfm Holley VS Thanks, Brad |
| Author: | Doc [ Wed Sep 15, 2010 12:30 pm ] |
Looks to me that you already have a rear end gear ratio, 3.55 So based on that and the fact that you want the converter engaged at freeway speed, I would shoot for 3000 stall. DD |
| Author: | drgonzo [ Wed Sep 15, 2010 1:37 pm ] |
Yes, I would prefer to use as much of what I already have if and when I can. Thanks for the info Doc. Brad. |
| Author: | 1974duster kev [ Wed Sep 15, 2010 3:32 pm ] |
I have 3.73 gears and before i put the 4spd in my 904 had a 3000rpm stall it was sweet as the car got faster i could foot brake a bit above 3000rpm also Kev |
| Author: | Dart270 [ Thu Sep 16, 2010 8:08 am ] |
I agree - 2800-3000 stall in a 9.5" or 10" converter. Lou |
