| exhaust manifold thread fitting? https://slantsix.org/forum/viewtopic.php?t=41919 |
| Author: | the_shadow [ Thu Sep 16, 2010 6:31 pm ] |
| Post subject: | exhaust manifold thread fitting? |
I bought a new OEM exhaust manifold off ebay, I think the label said it was from the 80s (I don't have it here in front of me). There's a threaded fitting about half way down, below the choke pocket...so the back side a couple inches up from the flange. First off, what is that for? Second, what plug or bolt size do I need to plug that off? It looked like a 3/8" pipe plug but it was a little loose and bottomed out (didn't plug) |
| Author: | GTS225 [ Thu Sep 16, 2010 6:40 pm ] |
Sounds like you're describing the approximate location of the O2 sensor bung. Your local exhaust shop or parts house should be able to fix you up with the appropriate size metric thread plug. Roger |
| Author: | emsvitil [ Fri Sep 17, 2010 12:03 am ] |
Dorman 65220 oil pan plug (18mm x 1.5 thread, 19mm hex head) |
| Author: | the_shadow [ Fri Sep 17, 2010 6:50 pm ] |
Quote: Dorman 65220 oil pan plug (18mm x 1.5 thread, 19mm hex head)
Thanks that worked perfectly!
