It is currently Thu Nov 19, 2026 8:27 pm
PostPosted: Fri Sep 24, 2010 10:35 am
My Duster has no AC w/904 tranny and has what I believe is a 19" radiator. It's not as fat as the AC radiators but it's not as skinny as some of the others I've seen. I'm not really sure how to tell how many cores it has and all that.
Anyway I'm about to go get a price quote from the local radiator shop but I wanted to see if anyone here knew of a good source to buy a new one online? I don't want to spend an arm and a leg but I don't want cheap chinese junk either. It doesn't need to be alumunim, just a stock rad since I never really had problems overheating anyway. Thanks.
PostPosted: Sun Sep 26, 2010 4:34 am
Check this site. http://www.radiators.com/manufacturer-m ... iator.html
I did not do a search, but you might find something that will work.
The best bet is to go to the shops that specialize in keeping older hot rods on the road, such as http://sachserodshop.com/catalog/index.htm
or one of the dealers that specialize in parts for these old cars such as Mancini. Pick up a magazine that is for street rod builders and you will find many resources for this kind of thing.
Sam
PostPosted: Sun Sep 26, 2010 10:12 am
The "stocker" would be the 19" radiator...the HD radiator is 22"...
You can also use radiators from the F-bodies, although I haven't tryed to install one of the 26", but it looks like it would fit.
According to my last supplier, I got one of the last new in box 22" radiators left in the nation....
PostPosted: Sun Sep 26, 2010 12:28 pm
Yeah I have a spare 22" radiator and after I installed it and fabricated a new upper radiator hose, I found out that the transmission lines wouldn't stretch far enough to screw into the radiator. Must be for a V8 or something.
Took mine into a radiator shop and he said it's not even worth fixing. The guy can get me a new one for $300 or an aluminum one for $220. I guess I'm just going to grab one on ebay or something and hope it works. Napa said their closest one was in Texas and after the freight charge it just wouldn't be worth it.
PostPosted: Sun Sep 26, 2010 7:26 pm
Look here. http://chucker54.stores.yahoo.net/pese.html
This is Mancini racing's Afco radiators. AFco also makes narrower ones as well. Mancini sells many other styles and brands, but this is your best deal, if you can find the size you need. If Mancini does not stock it, or does not want to order it for you, you can do a google seach and find one for sure. This is what I run in my car. New transmission lines are easy to fab if that is all that is needed to make the one you have work. I suspect year one, or Mancini both may have trans cooler lines for the v-8 radiator ready made.
Sam
PostPosted: Mon Sep 27, 2010 12:59 pm
Thanks Sam, I always forget about that site.
I actually ordered one yesterday morning from radiatorsgalore.com. It came out to just about $200 with free shipping. Hopefully it works for me. If I run into another transmission line problem, I'm sure I'll be on here asking what to do again.
