blower motor does not work
https://slantsix.org/forum/viewtopic.php?t=41957
Page 1 of 1
Author:  1974duster [ Sun Sep 19, 2010 12:27 pm ]
Post subject:  blower motor does not work
where can i get a new blower motor switch at ??
Author:  Chuck [ Sun Sep 19, 2010 12:45 pm ]
For a '74 Duster?
Author:  1974duster [ Sun Sep 19, 2010 12:52 pm ]
yeah i have been calling place around town and no one seem to have them
Author:  Fopar [ Sun Sep 19, 2010 12:58 pm ]
I looked on Schucks found nothing, tried Auto zone found for $17.?? order only.
Richard
Author:  1974duster [ Sun Sep 19, 2010 1:28 pm ]
the thing is my switch has 3 plug in the back not 4 plugs
Author:  Fopar [ Sun Sep 19, 2010 1:47 pm ]
Try this
http://www.ecrater.com/p/4054539/dart-d ... ter-blower
Richard
Author:  1974duster [ Wed Sep 29, 2010 10:05 am ]
so i got a switch that is the right one and i still get nothing i know that the blower motor work i have it wire so that i can still turn it on what else would it be the wire that gives it power have nothing so that is the problem just not sure how to fix it
Author:  newpoppop [ Wed Sep 29, 2010 10:20 am ]
it doesn't work at any speed?
Author:  1974duster [ Wed Sep 29, 2010 10:28 am ]
does not work at all
Author:  Old Car Scott [ Wed Sep 29, 2010 4:53 pm ]
Is there power to the switch?
Author:  Fopar [ Wed Sep 29, 2010 6:46 pm ]
Like did you check the fuse??
Richard
Author:  1974duster [ Thu Sep 30, 2010 9:08 pm ]
yeah the fuse is good the wiring is the problem i just need to find out where and i would be good to go i wish there was not tape on the wire that i am working on it would make my life easier
Author:  slantfin [ Fri Oct 01, 2010 6:59 pm ]
After the fuse, I usually check the bulkhead connector.
Author:  4speed [ Mon Oct 11, 2010 11:10 am ]
Some times the connector on the fan speed resistors melt down.
Author:  KBB_of_TMC [ Mon Oct 11, 2010 11:17 am ]
Just FYI: When I needed a new connector for a fan switch, I found that a GM connector (w/ the ears cut off) for something else (hi/lo switch?) worked perfectly - I just took the old one along to the store and looked for something they had in stock that looked close.
