It is currently Wed Nov 25, 2026 11:17 am
 Post subject: ebay spacer
PostPosted: Sun Sep 26, 2010 4:22 pm
would this be worth anything on a mostly stock 225? i dont even remember seeing this mentioned in any of the mopar 6cyl books.1 "spacer
1975 Plymouth Duster,225/6 2bbl. and duels, 904, 7 1/4
1986 Dodge Charger Shelby, 2.2 Turbo I, A525
PostPosted: Sun Sep 26, 2010 4:29 pm
It certainly CAN help. A word of caution though, be careful of following the " 6 cycl " books. They contain a lot of less desireable ways of doing things. I think you will find this forum MUCH more knowledgeable.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Sun Sep 26, 2010 4:32 pm
so far i have, especially when i compare the mopar recommendation to build a wild (on paper anyway) 14 or 15 second combination to someone on here that has a 12 or 13 second daily driver.
PostPosted: Sun Sep 26, 2010 4:43 pm
my brother has a 4 inch spacer that I ran for a while ...loved it.....
keep on roddin'
Site Admin
I'm not sure I follow that. I know of a couple 13 second street cars, but they are wild builds, or use power adders. Sub 15 second cars are going to be beyond mild themselves. Getting to 14 seconds with a BBD will need a hot build. it should put you into the 16's or 17's, but not with just a carb spacer and stock engine. There are a lot of other things needed to get there. Exhaust, head work, and weight reduction are needed.
The spacer will reduce heat in the carb, and can enhance torque characteristics. I take it you have a BBD super-six.
Measure carefully before closing the hood any time you raise the carburetor. The air cleaner stud can leave a nasty dimple in an otherwise pristine hood! :roll:
1" shouldn't be a problem, but check in any case! :D
CJ
 Post subject: hood clearance
PostPosted: Mon Sep 27, 2010 6:06 am
i have found a good way to check hood clearance: take an empty toilet paper roll and place it upright in the center of the air cleaner, close the hood. the roll will compress like steeping on an aluminum can and you can measure it :wink:
71 valiant 225, 904, 7 1/4
69 W200 power wagon 318, np435, np205, d44 front, d60 rear
Users browsing this forum: Google [Bot] and 11 guests
