| 73 dart back fires through carb https://slantsix.org/forum/viewtopic.php?t=41978 |
| Author: | 73dartswingr73 [ Mon Sep 20, 2010 4:36 pm ] |
| Post subject: | 73 dart back fires through carb |
My 73 dart is still running terrible but idling perfect today i would give it alot of gas in park and the car would die completely and a couple times i saw a good sized flame come right back up through the carb is this a timing issue?? or what else could it be?? thanks |
| Author: | wjajr [ Tue Sep 21, 2010 5:12 am ] |
Could be weak accelerator pump shot, causing lean condition during throttle plate opening. Could be dirt in carburetor. Could be timing, too advanced. Could be vacuum leak causing lean condition. Could be low float level. If you slowly open throttle, dose the engine gain rpm without burping through the carburetor? If so “Accelerator Pump†is number one suspect. |
| Author: | 73dartswingr73 [ Tue Sep 21, 2010 1:51 pm ] |
exactly i can lightly give it gas and it revs perfectly but if i go WOT fast it stalls or backfires throught the carb |
| Author: | Ricardosdemon72 [ Thu Sep 23, 2010 8:02 pm ] |
Lots of possiblities .... timing, lose timing chain, bad valves, unburended fuel left in intake runners.... start with the basics .. a lose timing chain will streach under loud causing timing issues... |
