| Truck bogs, stalls when I hit the gas https://slantsix.org/forum/viewtopic.php?t=42004 |
| Author: | 1974stepside [ Tue Sep 21, 2010 11:00 pm ] |
| Post subject: | Truck bogs, stalls when I hit the gas |
idles fine, but when I hit the gas it chokes, bogs and stalls unless I floor it but then it is slow. Was running fine until I didnt drive it a couple of weeks ago. Im gonna pickup a new fuel filter, any other suggestions? I've seen similar issues where it was the fuel pump but it seems like something is clogged. 74 dodge D100, 1bbl, 225 /6 |
| Author: | rustyfords [ Wed Sep 22, 2010 6:20 am ] |
It could be a bad accelerator pump. How long has it been since the carburetor was rebuilt? |
| Author: | 1974stepside [ Wed Sep 22, 2010 11:39 am ] |
Not sure when/if its been rebuilt, I've had it just over 2 years. was running and idling fine until recently. |
| Author: | Reed [ Wed Sep 22, 2010 11:50 am ] |
Could be the gas evaporated out of the carb causing the accelerator pump cup to shrink, leading to a loss of pumping ability. |
| Author: | rustyfords [ Wed Sep 22, 2010 1:23 pm ] |
Check for any vaccum leaks or loose/deteriorated hoses. As for the carb...it's not terribly difficult to take it apart to the extent that you can check the condition of the accelerator pump, however a quicker, but less accurate check is the remove the air filter, and look down the throat of the carb as you manually work on the throttle. If you see a nice, steady stream of gas shooting into the carburetor, then chances are the accelerator pump is ok. |
| Author: | 1974stepside [ Fri Sep 24, 2010 9:10 am ] |
The issue was a stuck choke plate. I started it and the same thing wouldnt idle, it would stall. Opened the air filter and made sure that the carb was squirting gas fine, I had to open the choke plate to check, once i started it again it was running fine. Thank you all...Have a great weekend. |
