It is currently Wed Nov 25, 2026 12:09 pm
PostPosted: Fri Sep 10, 2010 8:30 am
I sent my head to a shop to get reconditioned and they had to remove my intake and exhaust manifold studs to fit the seat and guide machine. When I went to pick it up, the studs had been pitched. I know I can get these studs included in the ARP head stud kit, but I don't want to use head studs. I just want to know the lengh of the studs and how much thread is on each side of the shank.
Any help would be appreciated.
Thanks,
John
PostPosted: Fri Sep 17, 2010 4:22 am
I'm not sure, but the last time I replaced the intake/exhaust manifold gasket, the studs looked to be sticking out about an inch and a half, more or less. On the threads, I would guess that they go from the tip of the stud almost to the head.
'78 Volare 225
'67 Charger 318
PostPosted: Fri Sep 17, 2010 4:23 am
Oh yeah, I read here somewhere that carb studs are the same as slant six intake/exhaust manifold studs.
'78 Volare 225
'67 Charger 318
PostPosted: Fri Sep 17, 2010 8:08 am
Reed had this same question about a month ago. See if he found a solution.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Fri Sep 17, 2010 12:38 pm
Manifold set to Cylinder Head Studs are 5/16-18 unc x 1/2" thread length (head side) by 5/16-24 unf x 3/4" manifold side.
The factory stud was 1 7/8" in total length so there was about 5/8 inch of unthreaded area between the two threaded ends.
Many of today's replacement "aftermarket" studs are either a little long (2 inch total) or a little short. (1 3/4" total) The thickness of the "spanner washers" to be used, will help decide on which stud to get.
The machine shop that "tossed" yours, should get you a set of replacements.
PostPosted: Sun Sep 19, 2010 10:46 am
Thanks,
I found a set specifically for slant six manifolds at www.silver-seal.com. 1.88 inches long... PN 6403... 8 bucks.
PostPosted: Wed Sep 22, 2010 2:58 pm
Thanks,
I just tried to order through their website and couldn't. Called the toll free number and the lady said I was her 5th complaint today. I just ordered over the phone. 36 studs @ .50 each. :D
Thanks for the link! 8)
PostPosted: Fri Sep 24, 2010 4:59 am
You are very welcome!
PostPosted: Sun Sep 26, 2010 8:30 am
Studs were in the mail yesterday. I would call that great service. :D
Users browsing this forum: Bing [Bot], Google [Bot] and 6 guests
