| Weber 32/36 bowl vent https://slantsix.org/forum/viewtopic.php?t=42073 |
| Author: | BUCKET 636 [ Tue Sep 28, 2010 2:37 pm ] |
| Post subject: | Weber 32/36 bowl vent |
I will be installing a Weber 32/36 DGV manual choke carburetor on my slant 6.One thing i noticed in the instructions is that the carburetor bowl vent is supposed to go to the charcoal cannister.My car doesn't have one,so would blocking this off with a plug cause vapour/pressure buildup inside the bowl ? Or would it be better to run a bit of pipe with some sort of filter on the end ? Cheers Greg |
| Author: | Wesola78 [ Tue Sep 28, 2010 7:09 pm ] |
I'm not an expert on carbs, but I think you would be better off with the pipe filter idea, rather than blocking it off. Or, you could probably just let it vent as is. Anybody else? |
| Author: | 66aCUDA [ Wed Sep 29, 2010 6:41 am ] |
I would just let it vent to air. Frank |
