It is currently Tue Nov 24, 2026 4:39 pm
PostPosted: Sun Oct 03, 2010 3:29 pm
Wanted to make sure I had identified everything correctly before ordering a FSM, here's the info I have collected, btw its supposed to be a 76
Engine Casting Nbr: 280683-9 0034: BH AAWJ
Engine Pad: 4 282 89 (may have been a : between 4 and 2)
Cylinder Pad: 4225R 115
Intake Manifold Casting Nbr: 4104595
I have a 80 FSM (Chassis-Body-Electrical) but need the engine manual or both if the FSM I have is too different from what I have.
See pixs here http://ssdadstreetrods.shutterfly.com/
Intro Post and Info here http://www.slantsix.org/forum/viewtopic.php?t=42107
Thanks!
35 Plymth Cpe - all Mopar running gear anchored by 76 225 /6 bored .030" over w/ 2 bbl Ddge carb, no bowtie in this street rod...65 Corvair FE, 64 Dodge RE, GM Alt, Stck Starter, TF 904 Tranny, 71 Pinto R&P Steering, 65 Plymth column
PostPosted: Sun Oct 03, 2010 4:52 pm
That is one really cool car, it is so good to see the SL6 in such a nice wrapping! :D
Olaf.
Aspenized
PostPosted: Sun Oct 03, 2010 7:57 pm
That is a really awesome car, congrats!
Scott - waywardgarage.com
Why is the rum always gone? Image
PostPosted: Mon Oct 04, 2010 7:05 pm
Ok, managed to ID the intake manifold while continuing to use the search function.
I have the Super Six 2 bbl setup!
I also have an idea of the meaning of 4225R 115, at least everything after the 4.
The engine VIN is proving to be a bit more elusive which is probably what I want to know the most, figures....
