It is currently Tue Nov 24, 2026 8:18 am
 Post subject: Using a /6 longterm
PostPosted: Wed Oct 06, 2010 7:54 pm
Ok, so I'm new to the inner workings of the slant as I continue to absorb material I've started to wonder what spare parts do I need to start collecting to keep the slant running for another 20 years
Assuming I don't have the room for a complete spare motor what would a top ten list look like?
I have a 225 Super Six set-up although the head is older due to the spark plug tubes that are in it. I found a late 70's Aspen nearby that I am going to go look at for spare parts.
Any suggestions would be appreciated...
35 Plymth Cpe - all Mopar running gear anchored by 76 225 /6 bored .030" over w/ 2 bbl Ddge carb, no bowtie in this street rod...65 Corvair FE, 64 Dodge RE, GM Alt, Stck Starter, TF 904 Tranny, 71 Pinto R&P Steering, 65 Plymth column
 Post subject: -
PostPosted: Wed Oct 06, 2010 9:01 pm
When your engine hits 150,000-200,000 miles,rebuilding the cyl. head and replacing the oil pump would be a good idea,other then that,keep on trucking.Replace the minor parts when they fail,or warn you they are close to failing.Adjust the valves on pre 1980 engines every 30,000 miles., and check the heat riser at every oil change.Use good quality oil and filters,and enjoy 300,000+ miles of service.My daily driver just clicked 220,000 and my father drove a S/6 pick-up for 370,000. :D
PostPosted: Thu Oct 07, 2010 3:56 am
I totally agree with bigslant6fan, spend your money on high quality oil and filters, good spark plugs and wires, run a regular maintenance scedule. My '77 Aspen daily driver has rounded 425.000 km (260.000+ mi), and it's the small things around the engine that are beginning to fail at a steady increasing rate. Things like fuel pump, starter, alternator, relays, distributor, radiator, water pump, all rotating parts that are not lubed by engine oil, will sooner or later get worn out, and things like hoses and belts also have a limited life span. Inside the engine, things like timing chain and valve guide seals may need replacement, and burning a valve or two happens! In addition to the auxilliaries mentioned above, having a complete spare cylinder head with manifolds attached, and also an overhauled carburetor, all ready to be installed, may be sensible to have lying around. I find great joy in repairing/improving things, as my car and engines is my hobby as well, but I'm annoyed when I have to repair things in the car, especially with a daily driver. Having a replacement part that you know work, is great!
On the other hand, it is a bit like when carrying an umbrella to be on the safe side, you can be certain it doesn't rain that day!
Olaf.
Aspenized
PostPosted: Thu Oct 07, 2010 6:22 am
Depending on year or mods: Ballast Resistor, Fuses, Dist Cap and Rotor (todays arent built well), Good (Curved to you liking) Distributor, EI module.
Just some random thoughts,
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Thu Oct 07, 2010 9:10 am
As noted above, it is good to have a replacement manifold set... or at least, a good replacement exhaust manifold. ( they are known to warp & crack)
Not much else to worry about with a SL6...
PostPosted: Thu Oct 07, 2010 10:00 am
Really the only thing that may get hard to find would be the spark plug tubes. They do wear out.
50 chrysler,54 Plymouth, 64 Valiant conv 4 speed, 66 Valiant V8 wagon, 70 Challenger R/T 440+6 conv 4 speed,80 Colt, 98 Neon ACR,84 Honda V45 Magna
Taking care of 57 300C conv,48 T&C conv. Missing my 67 GTX and 36 Ply coupe
Users browsing this forum: Google [Bot] and 7 guests
