| PCV Location: Carb Spacer, or Intake? https://slantsix.org/forum/viewtopic.php?t=42109 |
| Author: | Wesola78 [ Fri Oct 01, 2010 6:05 am ] |
| Post subject: | PCV Location: Carb Spacer, or Intake? |
This is for a Clifford intake that I may be using in the future. I have a 1 inch spacer that I plan to use, so should I drill and tap the spacer for a pcv port, or should I drill and tap the intake? Thanks in advance for your opinions! |
| Author: | 66aCUDA [ Fri Oct 01, 2010 6:10 am ] |
Will your carb not have one? Frank |
| Author: | Wesola78 [ Sat Oct 02, 2010 7:45 pm ] |
It is a Weber 38DGES. I'll check, now that you mention it, I'm not sure. If it does, that would make things really simple. Thanks for the response, I'll find out. |
| Author: | Wesola78 [ Sun Oct 03, 2010 8:42 pm ] |
Okay, I'm still not sure. I'm trying to find an exploded diagram of a Weber 38DGES that will show me where (and if) it has a PCV port. Anybody? |
| Author: | ceej [ Sun Oct 03, 2010 8:54 pm ] |
If you port it to number 6 runner, you will lean that runner. If the Weber doesn't have provisions for the PCV tap, then I'd put it to the carb spacer. CJ |
| Author: | DusterIdiot [ Sun Oct 03, 2010 9:04 pm ] |
| Post subject: | Yep... |
Quote: If the Weber doesn't have provisions for the PCV tap, then I'd put it to the carb spacer.
THe 2 barrel pintos had a spacer that had this provision, I also notice that Ford 4 barrel holley do not have a PCV provision, so they must use a spacer or manifold provision.-D.Idiot |
| Author: | Wesola78 [ Mon Oct 04, 2010 6:22 am ] |
Okay, I'll drill and tap the carb spacer. This is for a future project, thanks guys! |
| Author: | lowbudget [ Tue Oct 05, 2010 3:03 am ] |
Sorry steal to this forum but since we are already talking carb spacer port here..... If carb and spacer both have port which one is better to plug? Thanks Mike |
| Author: | coconuteater64 [ Tue Oct 05, 2010 10:27 pm ] |
Quote: Sorry steal to this forum but since we are already talking carb spacer port here..... If carb and spacer both have port which one is better to plug? Thanks Mike
The one you're not using! |
| Author: | 66aCUDA [ Wed Oct 06, 2010 5:41 am ] |
Either one should work fine. Frank |
| Author: | lowbudget [ Wed Oct 06, 2010 9:20 am ] |
Thanks, that's what I thought. Mike |
| Author: | emsvitil [ Wed Oct 06, 2010 4:42 pm ] |
Pick the one that you think will give the most even distribution to all cylinders. |
